120mm Delta's
18 Aug 2005
Shropshire
Do these fans come with a 4 pin 12v connector on them ?
I just want to fit them into my case, and plug in the connector :)
I was also told that they sound like a washing machine on the spin cycle :O
I would think that they do come with 4 pin 12v connections, as they are high powered fans that draw more current than a motherboard can happily supply.
as for noise - they are noisy beasts, but they shift a serious amount of air.
dont try powering one up while you are holding onto it. i did this, and moved my hand, it jumped, and sliced through my nail, and into my finger :eek: :(
They sound like absolute beasts :D
I think i might order two for my Thermaltake Tsunami..
But rename it,.. the Thermaltake Supersonic, Mainly because i know its gonna take off once i power it up lol
lol, get ready for the blistering whirlwind! And the immense racket! :D
I still have one of the 120mm beasts upstairs, at full power it sounds like a vacuum cleaner. Amazing cooling though, might stick one in my new case, with a fan controller of coarse :)
I ran one on my xp-120 and could bench in to windows at 4.2ghz on my p4 no problems like, temps were low
If you put it on the desk they kinda hover
I had 2 of these Fans, i sold them to a friend and he uses them in his server in the loft.
At night u can here the hum and slight vibration.LMAO :D
I might buy one of these just for the fun out of it.
See if I can make a helicoper out of it :p
how loud are these at 5v and 7v ?
Mate they are still loud at 7v, yes not as lound but boy the mate some noise :D Its to be expected.
To put into contrast how powerful they are.
I had 2 on my 120.2 rad sucking in, it could manage to hold a copy of fast Ford @ 12v. :D
they threatened to turn off my pc at a LAN because i had 3 of them on, also i then got my tshirt destroyed by one when it sucked it in :(
also it destroyed a cotton bud i put to close to one.
LMAO!!!!
I must order one just for the hell of it.
I used to tease my mate saying his computer was loud, but this should be funny :0
will be handy for when I need serious airflow when benchmarking, or when I'm really hot in the summer ;) Just turn my music up and I won't notice, lol
thats the whole point mate you can hear them over music... :rolleyes:
you could hear mine from the other side of the LAN, plus they were taking the mick stood there with paper seeing how far they could go with the paper and watching the fan blow the paper...also one guy complained his leg was getting too hot, as it was blowing all the hott air onto his leg :confused:
God not this fan nooooooooooooooo i pluged mine into molex and the dam thing took off i nearly lost a finger trying to catch it :)
Coldplay - Yes
Techno - No
And seeing as there is no chance of me listening to the first I think theres no problem :) Seriously though if you cut the molex off and join it to a fan controller the Delta can be kept in check when you want it quiet and be let loose when you want to bench/overclock.
