** 1TB of ultra fast storage at near 1GB/s speeds for less than £400?? Take a look inside! ;) **
20 Jul 2009
The bleak North East arm pit of Britain
Hello
Does 1TB of ultra fast storage approaching 1GB/s in transfer rates for less than £400 sound good to you? If so take a look at this beast!! :D
Looks to be arriving the first week of september too ;)
OCZ RevoDrive HYBRID 1TB PCI-E SSD Hard Drive - (RVDHY-FH-1T) ** PRE-ORDER PRICE ONLY ** @ £389.99 inc VAT
Unique Hybrid Storage Solution for Performance and Value
OCZ RevoDrive Hybrid is the next step in the evolution of storage technology for power users, multimedia designers and game enthusiasts. The PCI-ebased RevoDrive Hybrid not only eliminates the SATA bottleneck to unleash groundbreaking bandwidth and landmark IOPS performance, but it also includes a high-capacity harddisk drive and intelligent software that integrates SSD and HDD into a single high-performance and high-capacity storage solution.
The OCZ RevoDrive Hybrid comes bundled with intelligent caching software that dynamically manages the use of the SSD with the 1TB HDD for superior overall storage performance. The most frequently/recentlyused “hot” data stays on the ultra-fast SSD while “cold” data remains on the slower but larger capacity disk. Advanced caching algorithms learn user behavior and adapt storage policies to ensure optimal performance for each individual user. Welcome to the next generation storage from OCZ Technology.
Highest Performing Hybrid Drive on the Market!
- Completecaching solution on a single card
- SSD performance withoutsacrificing a low cost per gigabyte
- Delivering an exceptional all-in-one solution for power users, multimedia designers, and computing enthusiasts
OCZ SuperScale Storage Accelerator
- Facilitates scalable performance for intensive workloads
- Unique complex command queuing structure (CCQS) with queue balancing algorithms (QBA)
- Higher performance and reduced burden on the host CPU
OCZ Virtualized Controller Architecture
- VCA 2.0 presents as a complete storage subsystem for superior data management
- Only virtualization layer in the industry with TRIM and SCSI unmapsupport
- Enables SMART monitoring for system administrators
Intelligent Caching Software
- Simultaneously manages HDD and SSD, learning individual user behavior to adapt storage policies
- “Hot” data managed on Synapse SSD for highest performance, access, and bandwidth
- “Cold” data routed to HDD for highest capacity usage
- Capacity: 1TB total storage with 2 x Sandforce 2281 based drives (100GB) acting as cache
- Nand: 25nm MLC
- Storage: 1TB 5400rpm HDD
- Weight: 289g
- Interface: PCI-Express Gen. 2 x4
- MAX Read: up to 910MB/s
- MAX Write: up to 810MB/s
- MAX 4KB Random Write: 120,000 IOPS (475MB/s)
- Sequential Read: up to 290MB/s
- Sequential Write: up to 130MB/s
- 4KB Random Write: 32,000 IOPS (120MB/s)
- Product: RevoDrive Hybrid
Was £419.99 Inc. VAT
Only £389.99 inc VAT.
ORDER NOW
Bit of a difference there between max read and sequential read...
That's what I was thinking. A fast 7,200RPM or a 10K Raptor would surely be ideal for this?
Hello
Im not too sure but I believe its a 1.8" device which should mean very high platter density. 7200rpm or 10k rpm drives wouldnt be idealm at this size, power requirements would increase, as would noise and more importantly the cost for what would probably be only a small gain in performance.
Is that 100gb or 2X 100gb?
Its a 100GB unit in total.
Thats either going to be the use of Asynchronous NAND thats caused that or the HDD. More than likely the Asynchonous NAND as its internal bandwidth on AS-SSD shows to be a lot slower than other tests such as ATTO etc where by the drive would look far quicker.
No arguing that this is horrendously quick though :D
I hate when it say "Up to" but I had a feeling this one won't be faster than Vertex 3 because of Sequential Read & Sequential Write is much slower than Vertex 3
With a 100GB on-board I would have thought it would be faster, ie load all the data onto the cache when in use, and when idle move it to the 1tb part of the drive, will in simple terms anyway.
