Caporegime
- 8 Jan 2004
- Rutland
sam.wheale said:Oh yeah, also what's the 1T value for?
Thanks![]()
SW.
1T is command rate, I'm not sure of the exact value for your mobo.
Thanks![]()
SW.
sam.wheale said:
Minstadave said:Command rate should be in the bios as Command Rate, or 2T command (you want to disable it in that case).
Idle timer isn't worth worrying about, and TRC I don't think you can change in your bios so leave it be![]()
cymatty said:Hi sorry to go OT but is it ok if i add you to messenger? as you seem knowelagble and yoyu may be able to help me sort out my memory problem?![]()
Minstadave said:I was already helping in your thread, but you can add me if you likeNot going to be online tonight though, as I'm off to bed.
