Baz said:I am still surprised they do not use Methanol rather than petrol for fuel, as its safer for refuelings, how many times do you see a fire in the pits.. at least Methanol can be put out with water...
I like the idea of the split wings, but they need to put them back on slicks with one manufacturer,
get rid of ALL driver aids, no TCS, no ABS no power steering no auto flappable gearbox, use a sequential stick shift like Indy car and Cart.
limit the budget for each team to the same amount. this would keep all the teams in the same league.
get rid of the pompous white haired dwarf![]()
Methanol? More dangerous...
Seen several methanol fires in indy cars - no visible flames in bright light, all you see is the heat haze. Also - water doesn't help - it just spreads the fire out. Foam is generally whats needed.
F1 doesn't allow ABS anyway at the moment.
The biggest problem is when they go to a single tyre manafacturer *which will be Bridgestone* they have said publically that they will support Ferrari first and all the other teams after that.
So Ferrari will get preferential treatment over all others - again.
They need to go to control tyres really - Get someone like Avon or Goodyear back.
Simon/~Flibster
