Sorry to make another thread but the other is very large and many questions havent been looked at...
Currently running the S model of the 226BW.
Geforce 8800 GTX 768MB
Using the DVI cable.
Windows Vista Ultimate
Monitors native resolution according to the OCUK page is 1680x1050.
Mine only has:
1280x1024
and then the enxt option is
1920x1080
And thats my last 2 highest resolution settings. I cant see any other resolutions in the gaphics card options either to oerride the windows ones.
Running it in 1280x960 at the moment as that fits the best from the resolutions iv got available but its hurting my eyes a lot so im guessing this isnt a good resolution to the run the monitor at.
Any ideas how to fix this? I want to run the native res...
Mine only has:
1280x1024
1920x1080
Hope you get it sorted soon. It is a nice monitor.
I was hoping it was just some sort of software issue / conflict, but I tried everything I could think of and DVI never works at the proper resolution. At the moment I'm running on VGA and it works fine at the native resolution, but I don't know whether I should put up with it or return it. I mean, the screen is otherwise perfect and VGA looks fine, I just don't know if DVI would look significantly better.
