Not sure why this post is missing ?
---Quote (Originally by JAKUS)---
Yes , I see it does not have the connector. I understand you might be limited on Motherboard choice where you live, that's a great CPU but the board looks midrange ?
I have been running Asrock boards recently and they are very good see this one has the 4-pin molex...
http://www.asrock.com/mb/Intel/Z77 Extreme6/index.us.asp
I would try to get a better motherboard first before adding "fixes" your GTX580's are still good cards so it's worth it
What's with the 1200w psu
it will not be better as they split 12v rails and i think a single 12v rail is often better
---End Quote---
Yes it is a mid range board and qhe don't have a lot of options here, so i will have to stay with it, any problems? And believe, this board sells a lot gere and is very expensive, i saw some good reviews about this mobo, not as good as my old Rampage 3 Extreme but it was what my money could buy now, just spent almost 2.000 dollars just this time eith processor, mobo and psu
I've contacted EVGA and they will send me the EVGA Power Boost for free for me, does it will supply my issue?
My english is not so good soni did not understand what you said about my PSU, can you explain? )
PSU is the most important part of a PC
We have 2 types
1. The psu makes many single 12v outputs each with 1 cables/connectors
2. The PSU makes 1 big 12v output and all 12v yellow cables connect to it
The advantage of type 2 is, if connected components do not require so much power more is left for everything else.
Also If a GFX card suddenly needs more power than the limit of a "single 12v" it should be available
Your system will need about 500 Watts which is 42Amps on 12v so because we need reserve power you choose 60Amps, 60amps x 12volts = 720W single rail
If multi 12v you will need 3x12v outputs (2 for GFX , 1for CPU) that will be about 1000w psu
Both types will work ok, but unless you have 4 GFX cards and need extra connectors I would save the money for other components.
I hope you understand some of that
