290P/290X running temp comp
Man of Honour
21 May 2012
Dalek flagship
The rules are
Three times round the Heaven 4 bench (using the settings in that thread).
Stock clockspeeds on the GPUs (no overclocking or underclocking)
Any type of cooling allowed (providing it can run 24/7 so no LN2) please say which
Undervolting allowed
Custom fan profiles allowed
Screenshots of GPUZ at the end with max core temps and VRM temps displayed.
The object of the exercise is to see how cool the cards can run.
If anyone with any other cards want to have a go please do, all cards NVidia or AMD welcome.
I will run my 290Xs in the morning when I get in from work.
Please don't forget the VRM temps as it could help other people.
Card 780, GPU temp 67c, VRM1 temp n/a, VRM2 temp n/a, setter, Cooling - Air Stock gigabyte, Link
Card 290X, GPU temp 64c, VRM1 temp 44c, VRM2 temp 54c, Mr. May, Cooling - Reference Air @100%, Link
Card 780ti, GPU temp 60c, VRM1 temp n/a, VRM2 temp n/a, thefogo, Cooling - Air max fan speed 100%, Link
Card 290X, GPU temp 58c, VRM1 temp 35c, VRM2 temp 45c, Mr. May, Cooling - Reference Air @100%, Link
Card 290P, GPU temp 58c, VRM1 temp 49c, VRM2 temp 42c, LtMatt, Cooling - Reference Air @100%, Link
Card 290P, GPU temp 57c, VRM1 temp 46c, VRM2 temp 39c, LtMatt, Cooling - Reference Air @100%, Link
Card 7970, GPU temp 55c, VRM1 temp 53c, VRM2 temp 53c, wazza300, Cooling - accelero extreme cooler,fan 100%, Link
Card 780ti, GPU temp 52c, VRM1 temp n/a, VRM2 temp n/a, thefogo, Cooling - Asus DCU II @100%, Link
Card 7850, GPU temp 47c, VRM1 temp n/a, VRM2 temp n/a, wazza300, Cooling - msi tf3 non ref Air @100%, Link
Card 290X, GPU temp 47c, VRM1 temp 65c, VRM2 temp 48c, tommybhoy, Cooling - Modded AC Xtreme with Alpenfohn VRM heatsink, Link
Card 290X, GPU temp 44c, VRM1 temp 42c, VRM2 temp 36c, Kaapstad, Cooling - Custom Water, Link
Card 290P, GPU temp 43c, VRM1 temp 49c, VRM2 temp 43c, dribbler, Cooling - full cover ek waterblock and back plate, Link
Card 290X, GPU temp 43c, VRM1 temp 41c, VRM2 temp 35c, Kaapstad, Cooling - Custom Water, Link
Card 290X, GPU temp 42c, VRM1 temp 40c, VRM2 temp 36c, Kaapstad, Cooling - Custom Water, Link
Card 290X, GPU temp 42c, VRM1 temp 40c, VRM2 temp 35c, Kaapstad, Cooling - Custom Water, Link
Card 290P, GPU temp 42c, VRM1 temp 71c, VRM2 temp 55c, almighty15, Cooling - Thermochil PA 120.3 with 120x38mm Yate Loons at 5v, Link
Card 670, GPU temp 37c, VRM1 temp n/a, VRM2 temp n/a, OLDPHART, Cooling - Custom Water, Link
Card 290P, GPU temp 29c, VRM1 temp 29c, VRM2 temp 26c, Uncle Petey, Cooling - Custom Water, Link
Card 290P, GPU temp 28c, VRM1 temp 29c, VRM2 temp 24c, Uncle Petey, Cooling - Custom Water, Link
Card 290P, GPU temp 27c, VRM1 temp 30c, VRM2 temp 24c, Uncle Petey, Cooling - Custom Water, Link
I will run mine in the morning as well. I'll be doing a crossfire run as i don't want to take my system apart to do a single card run.
290X@1040/1300(Toxic Bios) Modded AC Xtreme with Alpenfohn VRM heatsink:
BUT
According to AB, temps hit 56c:
No 290 but I'll post my 780 Ti :)
Stock clocks and stock/1.2v. Not very impressive, my max fanspeed isn't fast enough :(
I can't hear it at 100% with my headphones on :o
Mine.
Single cover UK Supreme VGA block, 120mm fan blowing on the VRM's and memory.
Card is cooled by a Thermochil PA 120.3 with 120x38mm Yate Loons at 5v so stupidly quiet.
Could drop both core temps by upping fan speed and decrease VRM temps by actually fitting heat sinks to them ( Getting full cover block soon )
