290P/290X running temp comp
will have to wait till he replys and see or you could try setting yours down to it and force for a run?
On closer inspection thats core voltage. No idea how he got it that low. Maybe an error in reading from gpu-z, not sure. But mine fluctuates, his is solid and +100mv lower, somehow.
How do I check the asics ?
also I just used afterburner and set the voltage as low as it would go till it started atifacting.
Force constant voltage is off
and my fan profile is
Basically its quite till I game but normally sits around 55-60% when I game they have never surpassed 80 when I've been gaming.
Just noticed one of my cards has beat the 780ti for lowest temperature rock on AMD!!
Great work and that is indeed a surprise that you beat the 780TI. You must have some cool running cards. I've just don't some little bits with mine to try and see if i can lower temps and will run again now with the windows open. :p
Marginally better. :p
GPU1:67C
VRM1:57C
MEM:52C
GPU2:65C
VRM2:54C
MEM:49C
Not an entry Kaap.
Temps after an hour of BF4 with vsync off.
GPU1:86C
VRM1:76C
MEM:67C
GPU2:86C
VRM1:76C
MEM:64C
It does let me sleep easier at night when i see identical gpu temps. :cool: Although im a little bit disappointed that the MEM temps have a 3c difference. :(
that's with the ultra preset,quality ultra/tessellation extreme/8x aa
I guess your using the basic preset?if so ill try again later
7970 stock voltage and accelero extreme cooler,fan 100%
i down clocked my 290 to stock 975mhz its showing 1004mhz :confused: full cover ek waterblock and back plate all fans set to silent in bios.
[/IMG]
