290P/290X running temp comp
Afternoon Kaaps, my Heaven BMRK 4.0 results after 3 runs 4820k:4.6GHz-1.34v SLI 670 Stock > GPU1:1058/3004 / GPU:1084/3004 - Room Temp 21'c.
I don't think Vrm temps is supported with 670's > GPU MAX TEMP:37'C / CPU Core Temps:42'c 35'c 42'c 42'c
Note duting the 3 runs my SLI670's Core Temps fluctuated between 34'c to 37'c.
Custom loop -
PhoBya Rad 560+EK DCP 4.0 Pump (12v) with 4xZaward Golf II Fan 140mm 900rpm ZG2-140D - black
Watercool Heatkiller CPU Block Rev3.0 1366 / 2011 - Black Nickel
EK Water Blocks FC670 GTX GPU Water Block - Acetal+Nickelx2
Note Rad is free standing for better temps, easier maintenance and fitting.
Screenshot -
Cheers,
Oldphart.
Kaap you know im rocking reference cooling. ;)
I also know you are an ace modder, I was not sure if you have enhanced the cooling.:D:)
I will put you down as ref air.:)
It will be nice if we can get a good range of cooling setups which people can use to refer to.
Hehe true. I do have a pair of Accelero's that i could put on my cards but when i tried it on my 7950's the cards had no room to breath and (due to using 3 slots each) i got really bad temps so no chance of it working on these.
It would be nice if members mentioned what they were using for cooling whether stock or custom would be a good idea for GPU and CPU a swell.
Just gave this a go 3x benchmark runs on ultra 8x AA tess maxed cards at stock using my fan profile
80-77 on refrence cooling sandwiched together in a micro atx with 2 ssds 2 hdds and a 3930k lol
Only just noticed LT matt's is using 100% fan time for a rerun lol :D
LOL. Damn straight i am Mr May. It was like being at Heathrow. I should run it again to be fair. I did feel like i was cheating with that run. What fan speed were you using? I normally run about 55-60% fan speed. Your temps are really good i have to say. Its a testament to the design of the reference cooler that you can run like that with a lower fan profile and still keep decent temps.
One last time as I missed the under volting part :o
64-58 degrees
Wow you actually got lower temps than mine and you have a 290X vs my 290 Pro's. I'm amazed. :eek:
EDIT
What are the Asics of your cards Mr May?
blower cards do quite well when up and down like his pic
One difference i did notice actually. His VDDC in Gpu-z is a constant 1.000v where as mine fluctuates around 1.125v. That could explain the difference, other than that no idea. I wonder if hes using force constant voltage in afterburner?
