Tired with aquasuite and hwinfo shutdownyea it shows 1.4v on monitoring software because it is boosting 1 or 2 cores very quickly the changes in clock speed and voltage With me montoring though ryzen master jump around so quickly that you can't keep up. But boosting of 1 or 2 cores will show the voltage at 1.4v
It’s idling at 1.46v 33’c with all cores sleeping
Cinebench at 1.22v 62’c 3925mhz
Peak core set to 1.09v idle .24v and bench at 1.09v according average core v which is better but 3600mhz.
Oh bench at default is still 1.2 load 1.47 idle with sleeping cores, 3900mhz
So I’m theory I should be able to set to 1.2v and get 3900mhz it’ll probably crash I guess
Edit I think I have the wrong data source.
1.287v peak .50v average on master, should I be looking at the average to get my temp readings?
Because that’s the only data source that makes sense as it increases with load and it’s the only one changing as the cores go sleep
