Which block did you go for?
ek's new magnitude am4 nickel/plexi £179.99 got one from ocuk luckily was only 3 in stock when i bought one (i had the ek velocity am4 block before)
I have the Velocity at the mo..180 notes is a lot for a blockek's new magnitude am4 nickel/plexi £179.99 (i had the ek velocity am4 block before)
yeah it is a lot of money but if you read up on them they are individually made from a single block of material, lot of RnD, especially the am4 blocks, they are made for the chiplet design of said chips
Looks like you had the last one...
Was looking to get one later this weeki placed the order on Sunday and there were 3 looked early Monday and all were gone, so yeah very lucky to get one , if you check ek's website, the eta is mid april for more
Just comparing between ek and optimus right now.
Did you compare ek vs optimus before deciding which to go for?overclockers have different models of the block i got (mine was the nickel/plexi version)
they have
3 of the Nickel + Acetal (am4)
2 of the full Nickel (am4)
2 of the Copper + Acetal (am4)
now mine has had time to bed in my ccd temps are almost identical (ccd1@34 degrees, ccd2 @36 degrees) which is epic and load temps are with in 5 degrees of each other (70.3 degrees under load) and most importantly no temp spikes, it always stays at above temps at idle.
yes they are expensive but I'm pretty impressed plus they do look good
That is some really good performance there!i've always gone for ek, never used any other brand tbh, had a quick look at optimus products they do look good but until you said about them I've never heard of them.
i had the velocity block from ek prior to getting the magnitude, my temps on my 3900x were crap for some reason but switching to the new magnitute block and my cpu is lovely and cool at idle and under load (have a 4.4ghz all core oc @ 1.3v and max temp is 70.3 degrees with the new block, vs 83.8 degrees on the old velocity block)
Btw, can I ask what did you run to get your max temp? 70.3 with the new block.i'm not sure why the drop was so much but i'm not complaining at stock my chip runs around 34 degrees flat no temp spikes as before
