Nice.. What do you run 24/7 ?
Congratulations on a great build
I hate the stage where you can't do anything else and have to bite the bullet and put some fluid in
If you do retube then how about going from the top of the GPU bridge to the chipset block ?
Could you then go from the back fitting on the top rad to the VRM block, can't really see from the pics, that would tidy it up a little.
TY,
Toying with the idea of Tri Fire![]()
Thank you, glad you like it.
Its took a while but I think its been worth it
Tri Fire looks to be on the cards.
How do I get this moved to Projects
or do I do a new thread in that section?
Have you had chance to oc the CPU yet
I have finally got mine up and running
The good news is the mobo runs a lot cooler than my other X79 system and the CPU is about 7 - 8 degrees cooler.
The bad news is the performance on both my X79 systems is almost identical.
I hope you have seen more improvement than me.
mmmm 2400mhz doms, get playing with the base, IMC dependant you should see at least 2500mhz out of them
I would think a 3930K @ 5ghz should be enough to avoid a bottleneck with 3 Titans, though I suppose that also depends how well the driver/game scales with 3 cards too.
You get GPU blocks pre-ordered? Gregster was telling me Watercool are set to bring out some Titan Heatkillers too!
