Sorry was just going by the strengthening plate the non LT has, looks great either way.
They look nice and I would like to know if these come with thermal pads like the EK back plates? I am sure that will help a tiny bit with mem cooling.
Can't find anything to confirm this![]()
If looking around 900D pricing for a case, I URGE you to go look at the LD-PC-V8, yes it costs a little more but its just a stunning bit of kit, you'll probably never buy another case.
As for blocks, its a tough one, inverted motherboard tray with some nickel-plexi EK blocks will look incredible though![]()
Not much tbh, most prefer serial though. It also depends on the blocks you intend to use too, iirc my Aquacomputer block instructions state they are only to be used in serial due to them being slightly restrictive.
If EK it won't matter either way as they are extremely high flow in comparison to anything else on the market.
Edit: Actual differences is down to the flow path, with serial the fluid is forced through one block at a time, with parallel it flows through both blocks at the same time.
Have a read of:
Serial and parallel loops in general
I think as a general rule if you have a strong pump or multiple pumps then serial is better as the pumps get over the loss in total flow, if you have a weaker pump then parallel can help keep system flow but with reduced flow per component.
I have a D5 in my 670 Tri SLi with EK blocks in serial and flow is pretty good
ooo the XXL blocks, that the ones that cover the entire PCB??
Just looked over your build log, stunning system! Fingers crossed May/June I'll be building something similar.
How you finding the tubing? Has it discoloured at all?
Correct, but they are about 4-6 weeks away
And the heat these put out,
I don't know if I could wait that long
Then again the 900 is about that time frame b4 release
