Links fine.
me = jelly
What rad lay out are you going for?
A 560 would surely fill out the bottom nicely...
Edit: Only 12KG dry weight too, to give you an idea of how light that is, my dry weight is 26KG!!
I'd have a better measure up when you get it before buying the 560, I just had a read of the manual for the case, it says the bottom can hold either quad 120 or tri 140, no mention of quad 140...
A tough choice but I'd go with the black ICE rads, they have a really nice gloss black finish to them
Whats the part codes on the QDC's? iirc all my QDC's start something like 'VL3-xxx'
After twist locking them they just pull apart
That shouldn't be possible as there's notches on the male connector, unless they've somehow broke off. Make sure your pushing them in fully before twisting, it can take a bit of force.
Can you stick a pic up of them as together as you can?
Also the VL4 codes, is that whats on the packaging for them or whats actually stamped on the fittings? It sounds like you have one VL4 and one VL3.
That was the first thing I checked, the lugs are present they just don't engage/lock
If that's the case then seems like they don't match :/
Just to be sure, you're rotating clockwise right? And give them a good push before twisting, I was surprised how much force they needed. If you lightly push them in the notch won't be in far enough to lock in place.
Better off getting one controller and using splitters. You seem to have a healthy budget take a look at the aquero range by aqua computer.They push all the way in, lugs and all
Anyone know of a 10 or 12 way fan controller, otherwise I'll just get 2 x 6 way controllers
When pushing them in line the notches up with where the arrow is
Should be easy to tell if they fit properly
