Thanks for the piccy's,
Had a look at the website, I do like the look of them.
This one I do think would fit the bill - MAGNUM STH10
Don't mind the cost of the case it's the import duty etc that puts me off![]()
Nice
Build quality look up to the usual Corsair high-end standard?
Also if cramming a 900D with a lots of rads and blocks, I'd suggest giving consideration to moving to dual pumps in series, my single D5 is really struggling with an 8 component loop.
I was told pumps in series would be better as the higher head pressure vs dual loops would yield better results while giving redundancy if one pump were to fail.
Yep just add a pump so it would start res>pump>pump.
I'll be setting up dual d5's next weekend so I'll let you know how much improvement I see.
Two D5 pumps not only provide extreme performance, but give you unrivalled reliability. You also get the safety of two pumps, so in the unlikely event of a pump failure your system will keep on running. Together the pumps are so powerful they can pump to a height of 7.7 meters (that's about the height of the average house), but if you're worried about noise the pumps have a variable speed dial on the back.
This is the pump/res I use and the quote below gives an idea of the performance of two D5s.
http://www.overclockers.co.uk/showproduct.php?prodid=WC-184-XS&groupid=962&catid=1532
Had a look at this, it is a tempting option.
I wonder if they would swap the rad for one of these
http://www.overclockers.co.uk/showproduct.php?prodid=WC-162-EK&groupid=962&catid=1523
If so, then it would be a great option![]()
I would certainly ask, afaik the kits are made up from stock OcUK have rather then come in a big XSPC box like the EK kits, though Kaap should be able to confirm. If so it shouldn't be totally impossible to change the radiator over.
IF they can't, buy the above kit, flog the AX360, should have no bother selling it given its one of the top performing radiators on the market. You're essentially getting the rad, fittings and tubing for free in those kits.
ooo found stock at a few places now, wasn't any last week, I looked
Remember if you do buy it, you have to buy the 5.25 bay covers separate![]()
Nope, not that I know of anyhow, they were just quite swift in releasing the rev.2 (know as the +/Plus) after some flaws were pointed out in the first case. And the first revision looked like pinhead from hellraiser
With me not seeing stock for a while I just presumed they might have been refining something on it.
An LD build and possibly an H2+ build going on at the same time (you and Kaap) makes me want to push my phobya monstrosity in front of a train![]()
