3D Mark Mesh Shader benchmark released
Now available, benchmark your graphic's cards Mesh Shading ability to see how well your GPU is able to utilize this Direct X 12 Ultimate feature - we expect games this year to start using Mesh Shaders
https://videocardz.com/newz/ul-rele...t-results-of-nvidia-ampere-and-amd-rdna2-gpus
Some results below, ignore the Mesh Shader Off/On column, the important number is the % increase.
For RDNA 2 its around 550%
For Turing its around 400%
For Ampere its around 700%
its 1440% for AMD btw increase, need to update the post mate
Only Grim5 was impressed because the numbers on AMD cards looked so bad before the patch. :D
They’re still bad.
Yeah new AMD driver lowered fps with mesh off and that makes it look like it gets better gains but still worse than nvidia.. way worse..
6800 - mesh off 21fps - on 330. 1463% gains. Had 35 fps before the driver. Lel
Fail
