- 27 Sep 2014
Hi,
I'm looking to get some feedback on a proposed build that I'm planning within the next couple of weeks. I've been a long time Mac user, having gone through 5 Macbook Pros and two iMac's and I'm somewhat out of the loop in terms of PC building. The last build I did was back in the AMD Thunderbird days, so that's going back around 15 years ago. This is a totally fresh build with no parts having been purchased yet.
Anyway, the rig I'm looking to build will end up being used side by side with my iMac but will be used for the following:
Audio Production work using Nuendo and Adobe Audition (mainly sound design)
Games Development using Unity, CryEngine and Unreal Engine
Oculus Rift Use / Dev
Mobile App dev using Xamarin (One of the reasons I'm keeping the Mac)
Gaming
The parts that I have in mind are as follows, though any suggestions for things to be swapped out please let me know. I'm looking to spend around £3000 +/- 10%
Case: Corsair Graphite 760T
Motherboard: Asus X99 - Deluxe
CPU: Intel 5930K 3.50GHz
CPU Cooling: Silverstone Tundra Series TD02 Liquid CPU Cooler
RAM: Corsair Dominator Platinum 16GB (4x4GB) DDR42666MHz
GPU: 2 x Gigabyte GeForce GTX 970 G1 Gaming 4096MB
PSU: SuperFlower Leadex Platinum 1000W
Storage: Crucial M550 1TB, Crucial M550 256GB
Optical Drive: OcUK Value Blu-ray / DVDRW combi SATA - OEM
Monitor: Acer 4k2k XB280HK 28" G-Sync Gaming Widescreen LED Monitor
Sound wise I'm already running a Motu 828x which is a thunderbolt audio interface but I'll need a thunderbolt card for this new system as well as a switch to swap my keyboard, mouse and screen over to the Mac and back again. so any recommendations of switches that support 4K displays over display port as well as the usual USB ports for the mouse and keyboard would be appreciated.
Thanks in advance guys
Gaming
