3rd hard drive connection?
23 Jan 2007
I have 2 hdd's a C and D drive connected to the sata ports on mobo.
If I want to connect a 3rd hdd where do I connect it to.(not the raid ports I guess)I dont have a raid running I just want extra storage.Cheers.
Yeah, it should be as simple as connecting the drive up to the next available port. You using the red ones or the black ones at the moment?
OK, the black ones are the JMicron controller, the red ones are the four for the Intel controller. Just plug the drive in one of the red ones, it should work fine.
Just remember you'll need to partition and format the new drive in Disk Management before it'll be accessible.
