4090 Owner Monitor Thread
It's probably best if you sort your table by monitor model and not username, list names of users or count of users who use each monitor model. The current table in the OP post is already a mess and will only get worse if you don't make this change
Thanks for the info! I must say that the C2 doesn't look too big on your desk, although photos can be deceiving.
If I can find a desk that's 200-210cm wide (or up to 280cm wide if I swing my whole room around), I might just be able to put a C2 next to my U3323QE and have the best of both worlds.
@Sanjiv
4090 FE
48” LG CX OLED 4K 120HZ HDMI 2.1 (OLED48CX5LC)
Sonos Beam 2, Sub, 2 Sonos 3's for Atmos Sound
2 Desks to make it comfortable!
Coming from TN ultrawide it is night and day. With the OLED being "day" and hugely better
Hi, I'll do the sort at some point when/if I get a chance. Don't want to mistakenly put somebody in the wrong grouping.
Dell S2721DGFA 1440p @165hz
plus 3 other 1440p electriq screens @ 100hz
I think 1440p is a good resolution for the 4090... its still not beast enough for 4k at high fps frankly
Zotac Amp Airo & Gigabyte M32U 4K 144Hz.
In hindsight I should have got another curved monitor, maybe I'll swap it out at some point.
I caved in and bought an LG C2 Evo 42" (£799) to replace my Ilyama 40" 4k 60Hz (just a TN panel I think), I also have an HP X27Q (1440p 27" 165Hz) monitor I rarely use it for gaming though.
I got the 4090 mainly to drive my HTC Vive Pro 2 headset as the 3080 wasn't really up to the job.
Currently have a Dell S3422DWG which is 34" Ultrawide (3440 x 1440). Was considering the Alienware 34" QD-OLED but not sure if I can justify it for now having just spent £££ on the 4090 FE!
@Sanjiv - Thanks for adding me to the list, should also add my current monitor can do 144Hz refresh rate and HDR.
Thanks for providing more information, table now updated.
Alienware AW3423DW, lovely monitor only thing could make it better would be a bigger version of it thats like a 32" 16:9 in height instead of roughly 27" like it is currently
