** 4K GAMING 1MS 60Hz MONITOR @ SUB £500 !!!!! ** (IN STOCK NOW)
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
OcUK has made a deal with Samsung to the UK Etailor partner for their 4k Monitor designed for gamers and professionals, using a TN panel with 1ms response and 60Hz over DisplayPort connection:-
Samsung U28D590 4K 60Hz 1ms Widescreen LED Monitor - Black @ £499.99 inc VAT
Samsung U28D590 the Main feature of novelty is the resolution 4K (3840×2160), exceeding Full HD (1920×1080) four times. Natural color reproduction with soft color transitions is achieved, in particular, by playlist 1 billion colors. Response time is 1 MS, which perfectly fit to play the game content. Also amongst the peculiarities of the availability of an updated Picture-in-Picture (PIP 2.0). With its help it is possible to reproduce a picture of a small window in the original resolution up to Full HD (1920×1080 pixels) as the main picture is reproduced in UHD. In addition, when playing content small-resolution, innovative function UHD upscale will improve the clarity and quality of the image to the maximum possible resolution of 4K (3840×2160).
The novelty provides connectivity, audio-video devices: include 2 HDMI port and one interface connector Display Port. It is worth noting that the monitor can be connected at once two PC and play back content from both devices without any loss of quality, resolution images with each PC will 1920×2160. This monitor can be easily connected Xbox or PlayStaion4 via the HDMI.
Specification:-
- Size with stand (W x H x D ) : 660.9x486.3x169.4 (mm)
- Without stand (W x H x D ): 660.9x410.0x64.7 (mm)
- Packaging (W x H x D ): 794x452x109 (mm)
- Display Screen Size: 28" (70.8cm)
- Aspect ratio: 16:9
- Panel Type: TN
- Brightness: 300cd/m2
- Contrast Ratio: 1000:1 (Typ)
- Dynamic Contrast Ratio: 10,000,000
- Resolution: 3840x2160
- Response Time: 1ms (GTG)
- Color Support : 1B
- Viewing Angle (H / V ): 170 ° / 160 °
- Connectivity: 2x HDMI (30Hz), 1x DisplayPort (60Hz)
- USB Hub: NO
- Speakers: NO
- Warranty: 2yr
Only £499.99 inc VAT.
ORDER NOW
Stock is Expected at somepoint in May, there is no firm ETA apart from it will be May sometimes. Were expecting this monitor to sell like hot cakes as its 28", 60Hz, 1MS and 4k resolution for under £500, so we are expecting this one to run short, as such get your orders in quick to guarantee one from the first batch we receive.
That looks affordable, whats the catch?
It's TN.
But given the TN of my Samsung SA2300 700D, that's no bad thing.
How is it a gaming monitor, it only does 30Hz at 4K. 60Hz is at 1080p, or at least that's what I've been told on here.
DP it should be 60HZ 3840x2160.
HDMI it'd be 30HZ (I hate HDMI, never personally used it for a PC)
Everything I've read about this so far suggests it's 3840x2160@60hz over DP although it would be nice to have confirmation from OC on that point.
On another point, does it have speakers? It looks like it has a 3.5mm jack on the back panel?
Edit: just noticed the Speakers: NO bit...
That doesn't mean it has speakers (Which it probably doesn't)
If you use HDMI (I think DP does it too) it can carry volume to the monitor, the 3.5mm jack can be used to put that audio to headphones/speakers etc.
Do want
Unfortunately it is about 6mm too tall to fit under my desk surround, I will have to get my DIY skills out.
More seriously though I think trying to get playable frames on BF4 with a 680 won't happen.
Gibbo is there a 32 inch version coming in stock by any chance?
Might order one of these but wondering price of the IPS versions....though latest TN panels have improved a lot more over the last few years.
Nothing else from Samsung at moment, the focus is this model.
Do want
Could always run BF at a lower than native res. To my knowledge there are no TN panels for sale above 1920x1080 that have the 1ms response and 60hz refresh yet.
