Dude you should keep quiet about that kind of thing or b3mor might just track you down and nick your cpu!![]()
tri vs quad: what are you using it for? If you are worried about energy consumption maybe try it on tri for a while at the lowest vcore you can get it stable on and then just see if that meets your needs. If it is too slow go for the quad.
By this I mean how can I run it in tri core mode? If I select hybrid and enable ACC it unlocks to quad so as far as I can see I only have the option to choose between dual or quad. I'd like to try it out in tri core mode but i'm not sure how i'd go about setting it up correctly to work as a tri core. Anybody know?
