I have done a lot of reading and searching. Yet to find anyone that had this issue say they fixed it.
So what is causing my 5800x to immediately hit 90c when I start Cinebench r20?
It seems no matter how I adjust my bios it always hits the same temp in seconds. Is it a faulty CPU or MB?
Right now I enabled Precision Boost. I have it set to +200mhz and -20 on all cores in Curve Optimizer.
Still did nothing to the temps. Holds around 4550mhz all core during the run.
HWMonitor shows a max vCore of 1.488v and a max VDD of 1.531v. It seems to hold around 1.312v while doing the multicore run.
When gaming it is usually around 77c. I know these temps are listed as "ok" but I see others having way lower temps with the same CPU...
Using an Asus Strix b550-f Motherboard and a Corsair h115i 280mm AIO. The AIO is top mounted with fans exhausting out. Has 2 front intake and 1 rear exhaust fan.
If I missed any other info needed let me know. Thanks for any help/input!
