- 17 Jan 2007
- Nottinghamshire
Am looking to upgrade my current 3700x to an 5800x3D, but my only concern whether this will work on my MSI Tomahawk B450 non-max MB. Do you know if this does ? thank you
Apart from PCIe 4 only other thing I can think of is PBO2, but for X3D it's usually not available. Although some recent boards have had an update allowing you to undervolt with curve optimiser, but no idea if that's present for the B350.I'm in a similar position considering an upgrade from a 3700. I've got a Asus B350f gaming motherboard - various articles show that this does support a drop in upgrade to 5800x3d but while it is possible is the B350 missing too many features that the next couple of generations of chipsets added? Or is planning a full upgrade to AM5 the better option.
Think my current PSU is struggling as the PC shut itself down when playing FS2020 with my RTX2070 Super. Its a Superflower 550W
The card is fine as played other games which ran well. Is just FS2020 at the moment. My PSU is over 7 yrs old. Ran Afterburner and shown that Power drawn exceeded over 81% when playing FS2020whats the rest of your spec?3700x and 2070s should be ok on a 550w superflower - Are you sure it's not the card? how old is the PSU
Ah k yeah 7 years I believe it degrages at a few percent per year, whilst the wattage is not the issue the age might be, in that case is recommend a good 850w with some leg room for future GPU upgradesThe card is fine as played other games which ran well. Is just FS2020 at the moment. My PSU is over 7 yrs old. Ran Afterburner and shown that Power drawn exceeded over 81% when playing FS2020
