..The 7950x is due to be slightly higher priced than the 5950X was, however the lower end (which is still pretty powerful) is due to be the same. I'd at least wait until November time for some deals on Zen3
Just a heads up that the MSI AM5 motherboard pricing has been released and you're looking at the cheapest X670 motherboard of $300.Thanks for the advice, that was what I was thinking but haven't bought as generations change before so wasn't sure. Cheers.
Agreed. I'd keep my eyes open for a second hand CPU. Far cheaper and it's not like CPUs die as often as most other components so you don't need to worry about them as much.The GBP is in the gutter, inflation taking hold and passing along the supply chain, so I would expect any price drops to be mostly cancelled out.
Didnt AMD say a while back they would continue to sell AM4 alongside AM5? So perhaps no EOL 'lets shift the last of this' for a while.
Course I dont have a crystal ball so dont hold me to it!
AsRock dropped pricing that their X670E (not the stock X670) base price is about £290, however the X670 standard should be less than that and the B650/B650E again cheaper. a 5950X cheapest is about £520 and a B450 for about £75 (or X570 £140). Or A 7950x at £699 with £290 board and the performance is about 30% + then.Just a heads up that the MSI AM5 motherboard pricing has been released and you're looking at the cheapest X670 motherboard of $300.
There will be cheaper boards when B650 launches but X670 is going to be pricey. You could get a really cheap B450 motherboard which will still be fine for the 5950X and save a lot of money that way.
That's a fair point and I would agree with you that it can make sense to go with the newer tech if it'll be fully utilised and if OP doesn't need a PC upgrade right now.AsRock dropped pricing that their X670E (not the stock X670) base price is about £290, however the X670 standard should be less than that and the B650/B650E again cheaper. a 5950X cheapest is about £520 and a B450 for about £75 (or X570 £140). Or A 7950x at £699 with £290 board and the performance is about 30% + then.
Does the £989 outlay (assuming a bottom end X670E) compared to £595 with only a B450 board (missing feature parity) or £660 with X570 and a new system where later an 8950x or whatever can be dropped in as well as already be on PCIE 5.0/DDR5 make more sense because there no further upgrade path otherwise. If you then consider a B650 board end of October instead then you could be down to more like £839 price for Mobo/CPU then.
Indeed, I am just using the provided prices that have been leaked to date to get a rough idea of what to consider. You could move up and down the stack a little. I expect if you are using the 5950x/7950x then 32GB is really min to consider DDR was as well so if you consider that a decent kit of DDR4-3600Mhz with reasonable timings is about £120. DDR5-6000Mhz is about £200 (although deals on new can be had on eBay and such already as house mate got some for £140).That's a fair point and I would agree with you that it can make sense to go with the newer tech if it'll be fully utilised and if OP doesn't need a PC upgrade right now.
Too much speculation for now and with the launch of cheaper motherboards and cheaper CPUs, I'm sure AM5 will become a more and more viable option.
I certainly would strongly consider DDR5 for new machines with cheap DDR5-4800 available.
You could be right on that, I may be misrememberingFrom what I read the 7950X is coming in at a cheaper price than the 5950X launched.
Yeah if you are doing a new build. If you are just upgrading it's much cheaper to buy a 5950x than buying a whole new motherboard and RAM. I picked one up for around £500 recently for that reason7900x probably be as fast as 5950x in multi and faster in st and probably cheaper too
Indeed but this thread is about a new build so if happy with 5950x performance, you are likely to get 10-20% more for the 7900x still and be £100 then you could be comparing £739 to £660, so only a £79 total purchase cost for the newer faster platform whilst being able to drop a new chip in a generation or two and get a big boost again.Yeah if you are doing a new build. If you are just upgrading it's much cheaper to buy a 5950x than buying a whole new motherboard and RAM. I picked one up for around £500 recently for that reason
Yeah for a new build I would go 7000 series for sureIndeed but this thread is about a new build so if happy with 5950x performance, you are likely to get 10-20% more for the 7900x still and be £100 then you could be comparing £739 to £660, so only a £79 total purchase cost for the newer faster platform whilst being able to drop a new chip in a generation or two and get a big boost again.
