Or how about the numerous reports of 5dMKII compeltely failing relative to Nion bodies int eh sma econditions?
http://www.luminous-landscape.com/essays/antarctica-2009-worked.shtml
The same guy has several reports from earlier trips to Antarctica with the same findings, 1/4- 1/3 of all canon 5dMKIIs failing while no or very few Nikon bodies failing. And I have read similar reports all around the net over the years from safari workshops in South Africa, guided photo tours of Patagonia, Yellowstone photo guides, etc.
What about it? Lol
Where have I said the 5D, 1, 2 or 3 has weather sealing or at all? I was merely asking Rhys to be consistent in his posts if he were to pick holes in cameras and when being specific in one, at least be specific in the other.
People also forget something here.
For over a decade, Canon DSLR has 2 line of bodies.
A cropped and FF.
You obviously have alll the entry level with cropped as its cheaper to produce but even in the 1D, it always have had 2 lines side by side.
1Ds (studio) - FF
1D (1.3x)
It went on for 4 generations for the 1.3x. It wasn't until the 1Dx did they streamline the 2 together.
Under the 1 series you had the 5D and the 7D for the last 3-6 years with the mk1&2 for the 5D and 7D respectively. The 5D was designed and even market as a portrait camera and the 7D as a outdoor camera for wildlife and sports. It's built quality in weather sealing (I've said it now!) clearly reflect this.
Nikon on the other hand did not have such line up. They had 1 flagship and 1 under it. D3 and D700, the D3s came later on but they are all FF sensors. And they threw everything but the kitchen sink into these bodies rather than split them up.
It wasn't until the 5D3 they added the AF from the 1D, plus other bits from the 1D. It is clearly a change of strategy on their part, how much is it to do with Nikon's business model I have no idea as they sold both the 5D and 7D by the bucket load.
Anyway, the 1Dx and 5D3 is only the first incarnation of their new line up, a bit like when Nikon ditched the old Flagship D2N (or whatever the model number is) and moved the whole flagship/ top end model to FF. I'm not saying Canon isn't behind, clearly they are playing catch up in some areas, partly due to the split line up for a decade, but it will be interesting to see where they go from now on. They have the resource to pull it off if they want to, their budget for PR is probably bigger than Nikon's turnover.
P.s. Btw...giving all this credit to Nikon pushing sensor tech forward....shouldn't they give most of the credit to Sony? Whereas Canon design and build every part of their camera, including the sensor, Nikon buy theirs from Sony and tweak it. Although not really that important at the end of the day from a user point of view but I'd thought at least give credit where credit due?
