- 27 Jan 2003
- Chesterfield, UK
mortals said:Are you cooling the northbridge with a watercooler![]()
Not sure if it's possible (without adding more heatsinks for the power circuit?) tho as there seems to be a massive heatpipe cooler going across the mobo.
Maybe I'm worrying too much about the mobo etc but at those speeds, surely the northbridge is going to be taking some of the strain and heat.
Also looking at the heatpipe design it looks like it would be carrying the heat up to the power circuit?![]()
I have a 120mm fan on the heat pipe but otherwise stock apart from the cpu being under water
Heatwise i have not got a clue how hot it is. It doesn't feel that hot I think my hard disk gets far hotter to the touch
