Possibly, if you want the plug and play option with minimal effort involved other than having to restart your PC each time to switch BIOS between the two mode depending on if you want more performance/power draw/heat/noise vs less performance, quieter operation/less power draw/het.I've just picked up one of these cards, so appreciate you guys sharing this sort of info.
One question - I understand one of the options on the card is to physically toggle the bios to be software switchable... Isn't this the preferred option? That you I wouldn't need to keep opening up my case.
However, if you use MorePowerTool to edit power limits, the performance BIOS is completely redundant as you can have a custom power limit (above and beyond what the performance BIOS offers) and a fully customisable fan speed control with the Quiet BIOS (something the performance BIOS does not offer). When you take both of these into account, the smart play is to use the Quiet BIOS and extend the power limit if needed using MPT.
