Caporegime
- 18 Oct 2002
Try max'ing both and see what happens.
You've had a 6900XT before (so you claim), do you have the memory of a goldfish??
CrashesTry max'ing both and see what happens.
This card is different, if I set an overclock in the amd software like I have a thousand times before the driver hangs.
I have no idea where this card should clock at... Yet, and it's going to be a lot slower to find out with clowns chatting sxxt instead of giving helpful suggestions
Will do, only 100s of posts to go through, I'll just speak to him on discord instead, parp parp....?All the help you need is in the owners thread, plenty of info in there about overclocking if you can be bothered to find it. Parp Parp.
Search for LTMatt overclocking posts.
Thank you, that's all I needed, a rough ball park of where this card performs for others. Nice to see someone being helpful, much appreciated.From what's I've seen and experienced, most should do 2660-2760 as a daily, latest drivers have drastically reduced my overclocks, but before that I was able to get 2760-2780 in stuff like 3dmark etc.
As to settings, mine are
2660min - 2760max
Memory 2124 - fast timings
Powerlimit %15
MPT
420w
450TDP
Soc 60
Voltage 1200
Starting somewhere around 2600-2700 min/max is a good place to start as suggested above. Increase in 25Mhz increments until you crash. The power limits suggested above are good too. In short, @uksoldierboy nailed it too.Thank you, that's all I needed, a rough ball park of where this card performs for others. Nice to see someone being helpful, much appreciated.
2660min - 2760max
Powerlimit %15
MPT
420w
450TDP
Soc 60
Voltage 1200
Copied that exactly, couldn't pass a time spy with it, might just be the latest drivers like you said. But thank you again, as it will be great for gaming I'm sure
Just passed a firestrike ex with 2700/2800mhz gpu score of 32000 so its certainly capableTry 2610-2710, port royal seems to deal far better with higher clocks than timespy with these latest drivers.
