7800xt or 7900xt
What would you recommend for £300
£350 is where it's at. £300 is a no-mans land as there's nothing worth the jump from the £250 price point
so, if buying new, then either:
- the rx7600 or 4060 for£250ish
- or jump to £350 where you can get the rx7700xt or the rx6800 (non-xt)
re: 7700xt vs rx6800
they are both similar in performance and power draw (~250w)
the 7700xt has 12gb vram, the rx6800 has 16gb
if there is any potential desire to stream, then the 7700xt wins hands down as it has av1 support, whereas the 6800 does not
Just to refresh this is what I’ve ordered
I can’t increase my budget anymore already done that. So what could I change to fit in https://www.overclockers.co.uk/cart/restore/fb40d2a4c7b5a5098272a8d07a7e93dc
The reason for me buying from Overclockers is it’s not far for me to return anything if any components are faulty as don’t want to be waiting for couriers. So when I come to do an upgrade I was hoping I would only have to replace the gpu to 7900xtx for example. So what can I change that won’t reduce the performance that much?
