How high can I safely take the voltage? I was running at 1.214 last night
No, the core is fine up to 1200, it's the memory that kicks off. Can't get past 1300.
I think your going about oc'ing the wrong way with dual cards, you should always find the limits of each card first in single mode and go with the lowest clocks-though they can run on different clocks but it's easier if they are matched.
You don't need to remove cards btw, just switch off CrossFire and change the display cable to the bottom card and thats the one that will render.
Your vram needs more juice too by the looks of it, try matt's suggestion on voltage and push the power slider up to 40 if needed.
Does forcing constant voltage in AB not help alleviate the problem at all? I son't really understand why setting the clock and voltage manually doesn't stop all this.
I don't know mate - properly losing patience with it. Have put them on a popular online auction site. Will try again tonight but this is way more hassle than it should be. Guess this is why folk warned me off Crossfire!
It was pretty smooth before - it's just the boost spikes that ruin it.
As far as I can tell, yeah
Yeah, did that a long time back. I think I might have confused you a bit - I was saying that i was getting a perfectly smooth OC prior to the bios flash. The only problem I had with the cards before any of this were the occasional boost spikes. Post bios updates it's now freezing and crashing. Apols.
