Could try but bending it could result in the gbent area snapping. Yep that's the only issue.
Depending on the RMA consensus it may be worth a shot
Had a go at bending it, not perfect but looks better than it did before.
Let us know if it works, and if it does how high your overclock is![]()
If the cooler caused this then wouldn't the load plate be bent as well?
Form initial pic it certainly looks like CPU has been marked up by the notches in socket that are meant to stop you putting it in the wrong way - will be interesting to see if it still works!
Good luck OP! It's horrible when thing's like this happen!
I take it you won't be trying the corsair again - have you got a HSF you can use?Nothing so far, but trying a few things to try and get the original shape back
Jesus ... its likely the die area is dead as the bend is fairly inclinded . Personally id purchase the overclockers warrenty from.intel and then a fortnight later send it back for a replacement . Highly unlikely they inspect under those citcumstances .
Don't mean to sound nasty but doubt its the cooler. I've had mine maxed out with a screw driver and never had anything like that. I'm pretty sure the socket would be warped as it would have to bend that as well. Looks like the cpu has been put in wrong or not square.
live and learn i guess. Never know you may get lucky OP and it may work. Fingers crossed.
I'd say stomach the mistake and get another if its dead. Doubt Intel will take it if its damaged. They may take it if it looks fine and doesn't have any marks or the obvious bend.
