A new revision G80-450-A3 vs the GTX G80-300-A2. Slightly less power consumption at those higher clocks, so should clock higher. But £150 higher? They're having a laugh.willhub said:Wait a min, wasent there some info about the Ultras using different G80 cores aswell?
fornowagain said:A new revision G80-450-A3 vs the GTX G80-300-A2. Slightly less power consumption at those higher clocks, so should clock higher. But £150 higher? They're having a laugh.
The Halk said:Tested my GTX last night and it's stable at 661 on the core.
Translationspb251272 said:My GTX at 648/2052 would most likely out perform the ultra. The only way they may be slightly worthwhile is if they oc up to (or over) 700 on the core, which I seriously doubt, although 2500 on the memory would be good![]()
Typical? Too soon to tell, but there will be a few new records with choice cards. Keep any eye open for k|ngp|n's orb scores, but then again he gets them for nothing. I'll stick with my GTX for now.spb251272 said:Well if that's typical, then they may be worth the money after all, or at least after a bit of a price drop anyway
xtr3eme said:I think this will be 7800GTX 512Mb all over again....They were silly amounts of money too.
Azza said:Like getting rid of it completley.
What the hell was the point of this thing any way, they own the high end market right now and have done so since the 8 series cards came out.
They must have some pretty insane people working for them.
