The arrogant reply to overkill asking if he can send a pm to 5ub because he cant pm and you guys thinks he will put proof up. Lul.
He's at i50 therefore probably drunk.
Ok guys the correct answer on this one is 400KG. Which five forum members guessed correctly.
Well done to:
Rainagul
Overkill
Basil
Mickyfinn
Passey89
I only have two PSU to give away here though so the Tie breaker only to be answered by these five which ends tomorrow at 5 pm is how much weight do I use for dumbbell shoulder press for 6-8 reps. Unique guesses only please guys. Post your answers in this thread below this post. Thanks!!!
I thought it'd be around the 600KG range but then realised more than likely the training is the usual HITT crap so gave a generous 4something. Guess i werent too far ahead![]()
401Kg
Ok as none of the correct guesses responded the prizes go to the first two to answer correctly.
Rainagul and Overkill
I will PM you guys for addresses to ship the PSU's to now.
wow I can't believe non of them responded.Ok as none of the correct guesses responded the prizes go to the first two to answer correctly.
