8Packs Bday competition, prize give away.
Missed that bit. however, I suspect he wasn't expecting so many entrants. with 607 seconds per entrant it would give him less than two seconds per person to copy the username and weight into an excel file where, i assume, you can auto sort the numbers and usernames
He could have started compiling the answers long before the competition finished. :p
He's probably trying to wrestle the prizes out of some ocuk dons dead hands
The last post before the end of the competition was #345, so going from my slightly strange method of entering:
I would like to ammend my first guess to:
The weight in kilograms is equal to the number of posts there will be in this thread at the end, not including the post confirming that the window for entry has closed or any posts after this point, and not including the OP. :D
I can do that right? Makes me even less likely to win but it adds interest. :rolleyes:
I make that as 344KG. So that's my guess :p
Ok guys the correct answer on this one is 400KG. Which five forum members guessed correctly.
Well done to:
Rainagul
Overkill
Basil
Mickyfinn
Passey89
I only have two PSU to give away here though so the Tie breaker only to be answered by these five which ends tomorrow at 5 pm is how much weight do I use for dumbbell shoulder press for 6-8 reps. Unique guesses only please guys. Post your answers in this thread below this post. Thanks!!!
Ok as none of the correct guesses responded the prizes go to the first two to answer correctly.
Rainagul and Overkill
I will PM you guys for addresses to ship the PSU's to now.
