Or a problem with the rest of your PC, this can also effect loading times when the workload gets high.
I haven't got much things running when doing this test. The cpu is an i7 with 8gb of RAM so really shouldn't be a problem. Nothing else in my system takes this long to run or cause freezing.
The cpu usage doesn't go higher than 25% when running this test, even when the freezing happens.
