Yes you can set manual DRAM speed on nearly all boards.Does anyone know if and how you can manually decrease the DRAM frequency through the Gigabyte bios
It's either the multiplier or the uclock divider mode.I've found it it's just the multiplier isn't it I thought it was a different setting
EXPO is just a set of overclocking profiles baked into the memory that you can choose from within the motherboard's BIOS.Are you able to change the frequency when EXPO is turned on or does EXPO make it run at the fastest frequency
You can apply EXPO then change the memory frequency afterwards.Are you able to change the frequency when EXPO is turned on or does EXPO make it run at the fastest frequency
No consensus, just get a motherboard that works for you.although adjacent, is there a buying consensus for motherboards for the 9800x3d?
I'm getting the itch to upgrade for real.
What is the exact product code for that RAM? Is it 4 DIMMS?Been having a lot of trouble with posting with my corsair cl36 stuff since upgrading to the 9800x3d..
Are they Micron? Did you update the bios?Been having a lot of trouble with posting with my corsair cl36 stuff since upgrading to the 9800x3d.. I hope this fixes my issue..
There are multiple revisions of that motherboard and it comes in B650, X670 and B650M variations on top of the revisions.I've updated the bios several times over the last month, I think they're beta ones. F32g currently. It's a Gigabyte Gaming X AX mobo. A revision of which that appears doesn't seem to officially support the 9800x3d..
Ram. I don't know if it's micron. is it written on the sticks?
CORSAIR VENGEANCE DDR5 32GB (2x16GB) DDR5 6000MHz CL36 AMD EXPO Intel XMP iCUE Compatible Computer Memory – Grey (CMK32GX5M2D6000Z36)
And even with expo off I still encounter post issues at the dram stage light. But today it turned on 1st boot. Sometimes it even complains that the bios needs to be reset. Really annoying problem. I hope it's not the mobo really because it's such a pita to swap. At least the ram is easy!
So sorry, it's the B650! And rev 1.2.There are multiple revisions of that motherboard and it comes in B650, X670 and B650M variations on top of the revisions.
They should all have support for the 9088X3D since Gigabyte would have included the latest AGESA version in each BIOS buuutttt Gigabyte are weird and it might be a weird BIOS that needs fixed.
Looking at your BIOS version you're either on X670 or Z790 but I think I can guess which one lol.
Yup, Gskill/Corsair/Kingston?Teamgroup etc.what are some good brands for DDr5 these days? Is it still the same brands you were accustomed to seeing during the DDr4 days?
I figured as much, good to know they're still making good productsYup, Gskill/Corsair/Kingston?Teamgroup etc.
If all you need is DDR6000 CL30 pretty much any brand is fine.
The brand itself is not important.I figured as much, good to know they're still making good products
