980Ti Load temps
Mine's idling at 135MHz GPU clock, 202MHz Mem clock and 405MHz video clock. Now I've got the fan curve sorted, it's idling at 27C. Mine idled at 40C before I set a custom fan curve. With the MSI gaming, the fan is silent at 40% speed.
If you consider that without the fan it's a passive cooler, then I don't think 40C on passive cooling istoo bad. Bear in mind if you consider ambient room temp to be 21-25C, then that's only another 15-19C higher.
