- 28 Sep 2018
Does that mean that my OC at 5 ghz is not stable if it doesn't handle P95 avx small fft with D15 and is it worth upgrading to AIO liquid cooling solution for additional 300mhz push from 4.7 to 5.0 to see any noticeable gain in performance?
It means you can't run that particular test with your cooling due to the amps it pulls.'
However, P95 small avx is not a level of stress you'll get in any real application thus I recommended occt large/avx2, x264 stress test or P95 small NON AVX
