A few hints please...
If you push them too far once you have saved the settings it will keep restarting so you just enter the bios again and change it.
But sometimes it restarts and goes to like stand by mode and you cant do anything so you have to turn the pc off take the bios battery out and that should reset it self or reset the jumpers.
They have thermal throttling, if that's what you mean. When they get too hot they revert to a "limp-home" sort of mode where they drastically slow themselves down to keep from burning up.
right fellas, my moneys landed so todays the day i order
CPU - Intel Core 2 DUO E6600 £215.01 inc VAT http://www.overclockers.co.uk/showp...rodid=CP-128-IN
Motherboard - Abit AB9 (Socket 775) £82.24 inc VAT http://www.overclockers.co.uk/showp...rodid=MB-106-AB
Memory - OCZ 2GB (2 x 1GB) PC2-6400 £166.84 inc VAT http://www.overclockers.co.uk/showp...rodid=MY-072-OC
Graphics Card - BFG GeForce 8800 GTX 768MB £399.49 inc VAT http://www.overclockers.co.uk/showp...rodid=GX-035-BG
Hard Drive - Seagate Barracuda 7200.10 250GB £56.39 inc VAT http://www.overclockers.co.uk/showp...rodid=HD-079-SE
Optical Drive - Sony AW-G170AB2 18x DVD±RW £19.96 inc VAT http://www.overclockers.co.uk/showp...rodid=CD-054-SO
Power Supply - Corsair HX 620W ATX2.2 Modular £99.86 inc VAT http://www.overclockers.co.uk/showp...rodid=CA-004-CS
kindlly organised by stickroad and others
just before i order quickly
can anyone reccomend a good heatsink for the core 2 duo?
and can anyone suggest anything else that may be of some use to me?
cheers fellas
