A JRS project thread - 1968 Citroën ID19
JRS
JRS
6 Jun 2004
Burton-on-Trent
(alt. title - "How on earth Citroën didn't end up owning the entire industry I'll never know...")
For a little while now my dad and I have been on the lookout for another car project after our last one was cut somewhat short. We knew it had to be something quirky and classic. Initially we started looking at Citroën 2CV breadvans, but mum put her foot down over that. Then it was regular bodied 2CVs, and I'd seen a lovely early '60s example for sale in Dorset. But the more I looked at stuff, the more I found out that for not very much more money you could get into a DS-type.
I found an example for sale a couple of villages away and arranged a viewing and test drive. Driving it around ruined me for other cars. The way it loped along, utterly un-bothered by the horrendous state of the roads around here. I've driven some comfy stuff, but this was on another level. We didn't go for it in the end as there was a bit too much bodywork for my dad and I to sort at home, but then another car popped up on the market. Not a DS, strictly. The ID was the lower model, less powerful engines and simpler hydraulics - they retain the DS suspension, but the brakes are simpler and have a regular pedal instead of the mushroom shaped 'on-off' switch, power steering isn't fitted as standard and the hydraulic-operated semi automatic gearbox wasn't an option. This particular example was a non-PAS car, but had the later style front end with driving lamps that turn with the steering. I drove down the other week to crawl all over it and go out in it on a test drive. Some jobs to do, to be sure. But incredibly solid where it needed to be, and very complete. A price was agreed, and yesterday we fetched it home.
Having put about a hundred miles on it, I've learned a few things. One, the unassisted steering is rather heavy when there's only 26psi in the front tyres :eek: I remedied that last night. Two, there are stretches of the M1 (particularly around Newport Pag. services) where the road surface in an average modern car feels a bit...'lunar'. This thing barely even sees it - there's just this slight raising on it's suspension and a muffled thump sound and it serenely charges on. Three, Citroën really cheaped out on the engines in these cars. The unit in this one is the 1985cc engine, redesigned from the original 1911cc one with a shorter stroke and a five-bearing crank but it's not what you'd call refined. It is a hemi though, and with c.90hp it'll bowl along at motorway speeds without feeling like it's particularly struggling.
The brakes are exceptionally good - using the same high-pressure hydraulics as the suspension, you can really haul the car up in a hurry. The seats are superb, like living room furniture. Roadholding is excellent, though it leans a lot when cornering due to the way the suspension is set up (Citroën never really sorted that until the Xantia/XM generation of cars). The body cuts such a clean hole in the air at speed that you don't get a great deal of wind noise, and happily you can even roll the windows part down at motorway speeds without any roar. I say 'happily' because the ventilation is utterly bobbins :D I need to see for sure if that's an issue with the design or with this particular example, but I've heard other complaints about it being marginal before.
Stuff that we have to do
1) Wiper motor wiring is a disaster, needs re-doing
2) Side trim missing off of the nearside front door and offside rear one a bit damaged, needs a new pair or one new+one fixing
3) Headliner inside is gone, needs replacing
4) Paint flaking off the bottom edge of the rear doors, needs sanding back and repainting
5) Car is a bit scratched and grubby, needs a good clean and polish
6) Dashboard is untidy, needs tidying and paint
7) Drivers seat cushion has some stitching coming away and a missing patch on the squab, needs an upholsterer to make it good
8) Seatbelts are crappy fixed length ones and there's none in the back, needs retractables throughout
9) Engine ignition is still by points and condenser, needs electronic ignition
10) Car hasn't been driven for four years, needs driving :D
Pictures to follow as soon as I get home again, but a quick pic from yesterday - car too long to get into frame from where I had to stand!
Also note my fat frame reflected in that paintwork :o
And one from when I went down to view it the other week:
Grubby but sound
The office
The engine room
Like a carb but smaller :D
The wiper wiring disaster that's 'job number one' to sort :eek::mad:
Offside rear door and trim that wants attention
Absolutely fantastic :cool:
So many cars have a point to prove, that car is just above it all, completely effortlessly cool, hope you guys enjoy it!
I love these cars! I always wanted one when I was a kid.
I wish I had the space and know how to buy a classic and do it up. It must be so satisfying .
Mo' pics added.
Cheers Diddums. I hope we enjoy it too. Was a bit hot for pa today to try and take his first drive in it (he about branded himself on the metal of the seatbelt buckle!), but he moved it around on the drive and got the feel for the controls.
I won't kid you, space is one thing that you kinda need with anything beyond simple tidying as a project. But know-how is really easy to pick up. Cars from before fuel injection and widespread electronics are often a doddle to work on (think older Fords, BMC products, Mercs from when they were genuinely built like tanks rather than trading on past glories).
If they weren't so nickable, and being nicked with such alarming regularity, I'd recommend a Landy like our old one as a starter classic any day of the week. Easy to get bits for, only six moving parts all of which can be fixed by tapping on them with a hammer in vaguely the right spot and incredibly good fun to drive.
Other ID19 observations and weirdness
Some things that you don't really think about until you get up close. I was pumping the tyres up last night, and every time I do that on any of the more modern cars in our 'fleet' I end up with my hands black with brake dust. Not so here, and I didn't make the connection until I was indoors again - inboard brake discs :cool:
The engine is set very far back in the chassis, making it halfway to a front-mid design. This serves two purposes. One, weight distribution is improved. Two, spark plug number four is an utter ******* to change!
You can tell that the model line was designed around the semi-auto 'box and the mushroom brake actuator. Because the clutch pedal is at a very different height to the brake pedal which is itself at a very different height to the accelerator. This is not the car for heel-and-toe.
The parking brake is exceptionally good. Only better one I've ever come across was the Landy, and that acted on the driveline rather than the wheels.
The roof panel is made from fibreglass, for less weight and a lower CoG.
As you start to push on the brake pedal you can hear the hydraulics getting themselves ready to go full tilt on stopping the car. Hopefully I never have to find out just how quick they can bring the car to a halt...
Ha that's awesome! It's got the face from that Thunderbirds character, Parker? Not sure if you see it but loving this project!
Followed a completely beige one of these through the Tyne Tunnel a few days back. Went off at some pace, easily kept up with us lot. Was great to see, even with its 45 degree lean in the corners. :D
My front garden is so small I can't even fit my Gt86 on it. And 50% of the time the road is so busy I have to park in the next road. I would have to rent a garage somewhere if I bought a car to work on. It's just not practical right now.
My neighbour has two Land Rovers, one old the other fairly new. They must be enthusiasts, the old one looks like they've had it 40 years.
I like the BMW E21, they can still be got for a reasonable price.
Awesome. There was a moment a few months ago (after watching The Mentalist) that I looked around at these. However, the lack of a nearby specialist put me off.
Was fortunate enough to drive Citroen's heritage ID19 a while back – beautiful car and such a delight to drive (although a more modern engine/a mite more power would be nice). I'd have one!
Looking forward to seeing how this progresses. :)
Coward :D
That steering wheel.. Yuck! But the rest of the car is lovely
The steering wheel actually makes a lot of sense in-use. Just looks odd coming from virtually anything else!
Thanks to everyone so far for the kind words. If it's not stupidly hot later I'm going to get after the wiper wiring - pa would like to be able to drive the car at the weekend and rain is forecast. I'll probably RainX the screen as well, but I've never known that to do much until you're doing more than 45mph (at which point it becomes the single greatest product ever invented IMO).
F-f-f-following! Love these, they were completely amazing when they came out and are still cool as heck to this day. I watched a few videos about them and didnt appreciate how ahead of everything else they were when the came out. Truly futuristic... Whatever happened to Citroen? :(
This is deeply cool, don't know if you've ever watched but i really love coldwarmotors on youtube. He has a thing for old french stuff like this and i find it all really fascinating, they're just so different to anything else.
HubNut's coverage of the Citroen Centenary event is well worth a watch too. (as are all his other videos) :)
They built technologically advanced, quirky, ruthlessly individualistic stuff when all the market wanted was a boring, grey, mid-size saloon car that looked and acted like every other boring, grey, mid-sized saloon car. So they ran out of money and the French government strongly encouraged a merger with Peugeot.
But hey, even latterly there have still been sparks. Try a C6 sometime, especially one of the rarer-than-rare petrol ones if you can find one.
