Sorry if i omitted the p at the end oops. Now i appreciate what a difference that made Well things are looking good now im now in the f5 bios. Now will i go back and use the same f3 settings as before? If you can bear with me for another short period of torture Ihope to be able to run the orthos test tonight. cheers jos
Checked all settings ok but theres a new setting reading HIGH SPEED DRAM DLL SETTINGS Should I click on OPTION 1 or OPTION 2? Also CTRL and F1 wont bring up an option to unlock Can you help there
Yes thanks so much We're up and running I'll run orthos tonight for 12 hours and let you know how it goes
I appreciate all your support now sleep well and no nightmares about jos!!!!!!
Started orthos and it immediatelf failed! Then tried option 2 -would only boot on third attempt-and to default.Should i try tomorrow to keep upgrading very slowly at a stage until it refuses to run? What would you think of that? cheers jos
Cob, Thanks For The Reply, I Now Have Got It Up to 3 ,I lower DDR Overvoltage to 0.275v and The cpu Down To 1.35, Do You Think This Setting Is Ok,Or Will I Do The Above, Done This Before I Got Your Reply,
