When they film it at 1600 fps, it is very apparent that the V-Sync, triple buffer's is causing stutter (you count 1, 2, 3 and pause). Like I said earlier, we know it is there but we accept it because we are used to it and believed it is how it is and nothing we could do about it.
Removed!
Well..
This technology certainly offers an improvement over vsync if your using a mid range GPU. If you have a fast GPU, Ie GTX770 or above or 7970 or above and do you know what happens? The GPUs run fast enough that vsync is always in sync and the difference between the gsync monitors and an expensive lush IPS when you have a decent high end GPU and system is barely noticeable.
I personally would prefer a nice IPS over an TN panel as most if its use isnt going to used for gaming.
£400 for a TN monitor regardless of the technology is just too high in my opinion. If your spending that money on a monitor you have likely spent a fair amount on your GPU and the rest of your system.
If your looking to buy gsync I would wait until the new Benq units come out next year, far better price than £400 which makes the technology a much nicer proposal.
In the mean time, AMD may have something around the corner and you can mine on them where as the nvidia units you cant so perhaps it is worth seeing what they have coming to the table before making a commitment?
This coming from a 780-ti sli owner
Man, same monitor on here without GSync is 299.99
So they want a 141 premium just for the gsync
I'll pass
Well..
it all makes sense now
i wondered why Gibbo and now Andrew were so negative about G-SYNC when they haven't even used
you dont want people to buy the asus you want them to wait for the benq...
i wonder why...
As I continue to struggle to get my head around what it does it also strikes me it would be impossible for amd to do something similar for free? As its the monitor timing the frame release not the gpu, gpu still acts as normal throwing frames out at will?
i wonder why...
remember kids, the OCUK forum is a marketing tool, not a general tech forum
The sync range on gsync is from 30-144, so for example, bf4 vsync off my frames go as high as 160 & as low as 90 with a pair of 780's. So wouldn't gsync enabled give me a max frame rate of 144 (in the vg248qe's case) without tearing above and stuttering below? Genuine question btw.
I guess they may simply define an open standard that monitor makers are free to implement themselves without having to pay AMD for either licensing or the actual hardware.and without more details on AMD's solution it is difficult to tell, but basically yes, to get the monitor to change refresh on a standard controller usually requires a reset, so I am puzzled on how AMD are going to manage this without hardware in the monitor
Sounds legit. I'm interested to see AMD's version after Gibbo hinted it could be free.
