i'm sure one or two people around here have been expecting this post (mentioning no names - you know who you are
Yesterday I received the above processor. Having read as much as possible about the thing and support for it, I found out that Epox don't officially support any Turion or Newark E5 rev. cores for their desktop boards, and neither will they write in any support for it in future BIOS releases. My board is the 8N-PAJ PCIe.
However, on the back of reading a post on another board detailing a way to get these CPU's working in an Epox board, I went ahead and purchased the processor anyway.
Swapping out my 3700 clawhammer for the Newark caused the board not to POST, and the onboard error LED's showed a CPU error - which I expected.
The method to get the Newark to work is to disable cool n quiet and manually adjust the multiplier to the lowest (4x) whilst having the Claw in, then pop the Newark in. Then boot into windows at 800mhz - use whatever utility to increase the voltage and multi up to stock - which then enables you to adjust the multi and voltage in the BIOS, to ramp the chip up to stock - hey presto one working Mobile 4000 Newark ripe for overclocking.
Fair enough - everything was going rather swimmingly until I tried to adjust the voltage through windows - every time I tried it, the system hung and needed resetting. The multiplier could be upped to 12x, but it would hang at 13x. I used CPUMSR and CBID to attempt this under windows.
I also tried changing these settings through the BIOS, which caused some very strange results. No matter how many times I tried to change the voltage, it always reset itself back to 1.1 (stock is 1.35) and occasionally just wouldn't POST at all. The multiplier would change, stepping up in 1x increments. at 7x and 8x the BIOS showed stock voltage and the corresponding multiplier, yet as soon as i went past 8x it reverted back to 1.1v - then the CMOS needed clearing as soon as i went to 13x as the system refused to do anything at all.
The CPU reports itself correctly in CPU-Z, Newark mobile core, SSE3, 90nm etc. yet the only thing that seems to be holding me back is the system hanging as soon as I try to up the voltage in windows.
Now I know i'm going to get the 'why did you buy it if you know your board didn't support it' replies, but i've kinda got half way there by making the thing POST and being able to do certain things like up the multiplier in the BIOS and I've seen it report the voltage correctly (as well as correctly retaining my RAM timings which doesn't happen when it POST's at 1.1v).
So, anyone have any ideas?
)Yesterday I received the above processor. Having read as much as possible about the thing and support for it, I found out that Epox don't officially support any Turion or Newark E5 rev. cores for their desktop boards, and neither will they write in any support for it in future BIOS releases. My board is the 8N-PAJ PCIe.
but it's maxing out around 3.2ghz which is totally unstable.
