i have having almost the exact same problem as you in Bf2, when it loads up even on the menu, it freezes for a few seconds then comes back, and so on, i have a X1900XTX also,Coolasmoo said:Well, 5 seconds in the loading menu and it freezes up
didnt take long to do that test.
Back in Bios we go
Im also getting freezing in Firefox now aswell
My christ, what is goin on with this POS
chriscatt said:Hi, I think that flashing remotely is taking one hell of a risk, better to do it again correctly when you get in so as too make sure it's been done correctly...
ChrisC
TooNice said:The other thing is, Asus Update won't work anymore. When I first setup my PC, it was fine, now it gives me some obscure error about some DLL missing. So I uninstalled the app, then tried reinstalling it. It gives me one error box with a gibberish error message, followed by another one saying that it could not find an Asus motherboard
Installation via floppy disk is not an option: there is no functional floppy drive on this PC.
TooNice said:Yea, I sorted the Asus update problem. I am on 0404 now. It was a creative driver issue, there is a workaround involving renaming the Wow6432Node entry in the registry. I am not sure what it does really, but I changed it back after updating, so that part is sorted.
About the HD issue, I have installed the drivers, although I am not sure if it was installed properly. In the control panel, there is a Silicon Image ATA Controller entry. When I double click on it it shows the details of my drive. Int he Hist Link Speed and Device Link Speed section, they are both marked as Generation 1 (1.5GB/s). The Current Transfer Mode is marked as UDMA 6. When I look at the device manager entry, it shows the Driver Version to be 1.0.0.9.
There is also a "Flash Bios" option, but everything is grayed out there.
Okay, here is an update. I switched plugged my Raptor to the ULi controller, and everything is running at full speed.TooNice said:About the HD issue, I have installed the drivers, although I am not sure if it was installed properly. In the control panel, there is a Silicon Image ATA Controller entry. When I double click on it it shows the details of my drive. Int he Hist Link Speed and Device Link Speed section, they are both marked as Generation 1 (1.5GB/s). The Current Transfer Mode is marked as UDMA 6. When I look at the device manager entry, it shows the Driver Version to be 1.0.0.9.
TooNice said:Okay, here is an update. I switched plugged my Raptor to the ULi controller, and everything is running at full speed.
So that mean there is definitely something wrong with the Sil Controller, but I am not sure if it is just me, or every A8R32. Regardless, I am not happy leaving things as it is. Could someone test this for me?
Cheers.
TooNice said:Hi, thanks for the reply. You are actually connecting your Raptor to the ULi controller. That one works fine for me. The one I am having trouble is with the Sil controller near the back of the case (below the CPU socket).
