A8R32-MVP what is it
Just setup one of these A8R32's with an x2 4400+ and 2gb UCCC DDR.
Running at 2.6Ghz 10 x 260 and 1:1 on the ram !!
Nice setup with an X1900XTX :)
Latest bios loaded before I began to o/c.
U gonna give me the money for the RAM and CPU? :D
Hi FerociouS, I'd would have thought that your PSU should be able to do the job. It's just that I've heard of faulty or underpowered PSU's giving off strange symptoms such like you describe. Have you all the lastest drivers? ULi 2.20 http://www.nvidia.com/page/uli_drivers.html Reaktek R1.44 http://www.realtek.com.tw/downloads...52&famid=2004052&series=2004061&Software=True
Or have you a third party soundcard, if so remove it and try with the onboard. I'm actually using a SB Audigy 1 as I found that the onboard occassionally gave the odd stutter. Another thing to try is to disable all onboard devices you aren't using thro the bios.
Also test your ram with memtest, each one individually first then both together. Again you could try running your system with just the one in place and see if that makes a difference. My Corsairs were faulty, would only run with one in place, however they ran ok in another mobbo. Had them replaced with the same and things are now ok.
I have no lockups with my system, similar to yours, so something is up somewhere...
ChrisC
hi bito did you get a8r32 deluxe from ocuk l am going to order one next week now on hol`s for 2 weeks so give me time to test it , and you no what i am going to ask what`s the motherboard rev number would be very handy to no. :)
ChrisC
I am using the onboard sound m8, i dont have a sound card, i will check those updates out and get back to you, thanks for your Help Chris, appreaciate that m8. :)
Anyone have empty area in Control Panel Sata controller? :confused: Using latest SI sata drivers.
Hi Squiffy, something weird going on here, mine show no flash bios tab. Check your driver date and version in the next tab...
ChrisC
Nothing in the BIOS tab either, all boxes are empty like the one above.
Using drivers from silicon image site (3132)
Device manager
1.0.16.0 0 - Silicon Image Sil 3132 SATALink Controller
Hi Squiffy, my driver version says 1.0.5.8, dated 23/12/05, check you actually have the latest version here http://www.nvidia.com/page/uli_drivers.html
Edit sorry my error I'm looking at the ULi drivers, I don't use the sill one as it's slower...
Tom|Nbk
Yes I have but I don't use it, if you could possibly post up your queries here or PM me...
Cheers
Chris C
Tom|Nbk
Cheers
Chris C
just my random freezing issue i just wanted to know if it was down to the drivers/irq sharing etc its self as i got them while watching video and sometimes listening to music, i am using the Uli controller but i didnt actually have those drivers before maybe that was my problem i havnt had a lockup as of yet, so if i need anything else ill be sure to post it up :) , cheers chris
update: after installing those uli drivers i now get slight sound stutters in bf2 it normally happens when i join the round and i walk around a bit and the map then loads and as it does i get a slight sound stutter which is quite annoying any ideas chris i didnt get this at all before :( but i did get freezes and pauses etc every now and then
edit : ok half way through loading bf2 then a total lockup/freeze, im starting to think it could be my oc im going to flash bios again and start fresh, this was also after i uninstalled the uli drivers so it obviously wasn't those :rolleyes:
squiffy said:
Using on-board audio? Try updating drivers. I use the ULI 1575 and SI 3132 drivers.
turns out it might have been the dual core optimizer hotfix and driver i had installed that might have caused it, check cpu forum
Hi Tom i see your using on board sound have you got pci sound card you could use.
