- 14 Apr 2014
- East Sussex
I would clean install Windows at this point tbh, it's only going to take a few hours and might save days of messing about.
Is that what my results are suggesting to you?
Not to me, try what Amageus said and set all power options to prefer maximum performance in windows and the same in the Nvidia Control Panel.
Yes and also there is an option that says power management, set that to prefer maximum performance.Performance rather than quality in Nvidia?
I notice it also says perfcap reason is due to power, are you sure your PSU is up to it? can you check the output of it, on the sticker it should be listed.
Have we actually confirmed the hdmi is connected to the 1060 and not the motherboard?
Yeah its not raising clocks by the looks of it, those core clocks should be more than ten times that number.
I dont think your card is physically broken, its almost certain a windows/driver/bios issue.
Edited to say
Try creating a brand new user profile in windows (an admin one of course) and rerunning the tests from inside it.
Might be a startup app or some other crap causing bedlam.
When you have it open in GPUz, click the little question mark on the right hand side (next to the bus interface info) of the main screen and run the render test. See if that puts it into 3D clocks and spins your fans up.
I'll give that a try also. Thank you.
Yes. The only HDMI output is on the GPU card itself.
Quite odd this, i take it there is no overclocking software running as a service or app in startup.
A new user account would help with a corrupt registry assuming it was in the profile area.
