A 318 auto is capable enough of nearly seeing an indicated 135mph, which is what I assume the story is referring to.custom1 said:But as a fellow poster has said 135 out of a 318 auto.....yeah right pull the other one..
Freefaller said:Of course I'm sure everybody here would have reacted perfectly and wouldn't have been scared....
Phantom said:yep.
i hope the police fine him for using his phone while driving![]()
PMKeates said:A 318 auto is capable enough of nearly seeing an indicated 135mph, which is what I assume the story is referring to.
BeaumonT said:If your doing 130mph ish and your not sure if your steering lock is going to come on if you turn the ignition off would you try it ?
Here's the thing, your car is designed to have no power stearing, his isn'tchopchop said:hm what a retard, you dont loose brakes and you dont loose steering by turning the engine off.
i guess i have no control over my car when i go 120mph with no powersteering![]()
The weight of steering isn't really an issue at high speed.Gentwee said:Here's the thing, your car is designed to have no power stearing, his isn't![]()
Without PAS on my car the stearing is a lot heavier and harder than on my old non-PAS car
NickXX said:Erm, no it's not. Not an R-reg e36.
NickXX said:What an absolute attention seeking muppet. A 318 auto won't hit 130mph anyway.
He could have braked to 70, then in the hard shoulder flicked into neutral or killed the engine.
UNbelievable.![]()
Enfield said:Indicated 135mph, he said he couldn't get it into neutral because the gears were jammed and he couldn't kill the engine because it has PAS.
I suppose you could have controlled it at those speeds with no brakes, yeah?![]()
NickXX said:Ok I retract my earlier statement, *maybe* it did see an indicated 135.
You would have enough boost left in the brakes to stop after killing the engine. However, like I said, why couldn't he have killed the engine, engaged neutral and then started up again?
And yeah right the gears were jammed, failure of the autobox and accelerator at the same time? Hmm..
