geiger said:I cant hear the audio bbc thing because it crashes firefox and fails in IE. realplayer streaming crapness I think
Here, try this one mate
http://news.bbc.co.uk/nolavconsole/ukfs_news/hi/newsid_4790000/newsid_4796400/bb_wm_4796468.stm
I wouldnt go that far, but i have to say im glad someone else is with me in the general opinion of it all.DAvE18 said:sometimes you lot make me sick
I don't get it. Anyone with some common sense could have just turned the key to 1 and still remained in full control of the carwilld58 said:I wouldnt go that far, but i have to say im glad someone else is with me in the general opinion of it all.
Enfield said:1st gear? He was going '135mph', that' 5th :| Massive difference.
Still, how is that going to lock the rear wheels? Cutting the ignition to an engine doesn't instantly grind the engine to a dead stop.Vertigo1 said:The torque convertor, by virtue of the braking effect the engine will place on it relative to the rest of the drivetrain. There's no clutch in an auto and the wheels are never fully disconnected from the engine. This is why you shouldn't tow autos more than a short distance at a low speed.
Mystery Shrouds Runaway Lorry
Mystery surrounds the runaway lorry that careered down the M1 at 80 miles per hour.
Lorry driver Michael Rayner was hailed a hero after he brought his lorry to a standstill on the motorway near Scratchwood Service Area after the accelerator had jammed.
Scania, the manufacturer of the lorry, has said that an investigation into the incident has revealed that the speed limiter, that should have kept the speed of the lorry down, had been replaced with a non-Scania engine-speed limiting device which damaged the truck's throttle linkage, forcing the accelerator to jam. Both the speed limiter and the braking system were found to be working properly.
The Metropolitan Police have launched their own investigation into the incident.
Mr Rayner, 26, from Hawkshead Road, Little Heath, near Potters Bar, was driving the 38-tonne articulated lorry southbound on the M1 on Sunday when his accelerator jammed just after he reached junction ten at Luton airport.
He frantically pressed the brakes which fused the brake pads and put them out of action.
He dialled 999 on his mobile phone and Hertfordshire police sent a car and a helicopter to join him at Hemel Hempstead.
PC Patrick Jones of Hertfordshire traffic police was in the car that joined Mr Rayner at junction eight. He said: "We tried to get the rest of the traffic out of the way so that he could use the whole motorway."
The police control room was giving advice to Mr Rayner while he was driving, but PC Jones said that the driver's mobile phone would occasionally cut out. "When that happened, we would pull up beside him and I would shout advice to him out of my window. I was trying to reassure him all the time as he was panicking a bit," he said.
The police told Mr Rayner to switch off the engine while he was driving or put the gears into neutral so that the lorry could slow down. But PC Jones said: "As he had not been driving HGVs for very long, he did not know what would happen if he did either of those things. He knew that if he switched off the engine there was a chance that the power steering would fail and that was something that he did not want."
When the truck reached Watford, more police cars joined in to keep traffic away from the vehicle.
As the truck passed Scratchwood Service Area PC Jones said he told Mr Rayner that he had no choice but to turn the engine off. "We were only one or two miles away from the Staples Corner roundabout and the consequences of a 38-tonne lorry crashing into that does not bear thinking about."
Mr Rayner pulled over on to the hard shoulder and switched the engine off as he drove into the crash barrier, coming to a halt near Scratchwood Services. He escaped unhurt, although he was badly shaken.
National newspapers revealed this week that Mr Rayner served five years in jail for assaulting a toddler. The reason given at the trial was that he was suffering from the attention seeking disorder. Mr Rayner has denied that he suffered from the disorder and that he had tampered with the controls of the lorry to cause the accident.
Converted for the new archive on 30 June 2000.Some images and formatting may have been lost in the conversion.
9:30am Saturday 16th May 1998
I see your point there. I suppose it's possible that the wheels and drivetrain, via the torque convertor, would keep the engine turning over at a decent rate.Bug One said:Still, how is that going to lock the rear wheels? Cutting the ignition to an engine doesn't instantly grind the engine to a dead stop.
Mr.T said:Out of interest what would happen if you turned off the engine at 100 plus then tried to start it again ( at 100)?
Vertigo1 said:I see your point there. I suppose it's possible that the wheels and drivetrain, via the torque convertor, would keep the engine turning over at a decent rate.
I assumed the resistance of the engine to being turned over by the drivetrain, especially in a high gear, would be too much and the wheels would lock up. By "lock up" I mean slow enough to lose traction with the road, if not stop completely.
Simon said:Turning the key from 2 to 1 would have cut the ignition coil and fuel pump off. The key would have still been in and so steering would not be a problem.
Regardless of anything, with the throttle fully open there would be no vacuum in the inlet manifold so the brakes would not be assisted, however they would still work, even if they failed the car would soon roll to a stop
He could have quite easily stopped the car IMO.
chopchop said:it only works one way, that is that the engine must be running for the gearbox to send power to the wheels. the wheels cannot make the engine turn.
