I did the research on this before I re-built my file server.
<snippered>
Best of luck...
Great first post, And CLAIMED
<snippered>
Best of luck...
Best of luck...
I concur with all your conclusions and welcome to the forum![]()
Also need a fast nic for rac nodes and storage have been looking at "Intel ET gigabit nic (Intel 82576 controller)" or "HP NC382T nic (broadcom 5709 controller)" anyone used either or these and can recommend or advise against?
Thanks
For example 100mbps is ample for streaming even 720p content from a server to an HTPC.
^ Indeed. 100Mbit ethernet can easily do 1080p, in fact it can probably do about 5 concurrent 1080p streams quite easily.
Er, no. I've got a blu ray 720p rip that requires about 50 Mbps at peak, so you might just get 2, but 5, no chance.
I bought some cheap 85mbit homeplug adapters to connect my brothers '360 upstaires as the wireless in my house doesn't give a good enough signal in his lounge.
Anyway, these things only transfering about 1.95-2.15MB/s so not very quick. However, I was quite happilly watching Rambo 1080p on his '360 and whilst all the action was going on there was a hardly unnoticable pause, but apart from that it played quite well!
