Sit rep.
Just did a tally up and its not as bad as I thought just yet.
£3300 or there abouts is what the project is currently sitting at, which includes:
The car
Full Comfort Leather interior incl. door cards
MTechnic 1 385MM steering wheel
Tailor fit floor mats
Leather gearstick gaiter
Re-trimmed original gearknob with new leather
Replacement knee roll panel
Boot cubby covers
Drivers door seal
OEM rear speaker pods
4x Alpine speakers
Drivers door scraper trim
Drivers door sensor
Boot hinge covers
Valve cover gasket
Rocker end plugs
Spark plugs
Sump pan gasket
PAS resevoir
Clutch slave cylinder
Brake pipes
Front nearside wheel bearing
Brake pads with wear sensors
Drop links
Control arm 'lolipop' bushes (E36 M3 bushes)
Gearbox oil
Differential oil
Rear nearside brake caliper
Fuel filter
Oil & filter service
Wiper motor (intermittent wiper functionality restored)
Prop shaft centre bearing
Prop shaft to gearbox flexi coupling
Selector shaft oil seal
Fuel tank
Filler neck connecting hose
Exhaust manifold
Full exhaust incl stainless Scorpion mid-section
Exhaust downpipe bracket
Genuine BMW 15" Basketweave alloys including spare
5x genuine centre caps
Front and side amber indicator lenses
Boot glass lower rubber trim/seal
Nearside tail-light
Offside tail-light
Drivers side door mirror
Numberplates
Complete bonnet
Nearside front footwell rubber/metal grommet
Front fog lights
Genuine bonnet badge
Genuine boot badge
Replacement inner sill, outer sill, and rear arch for nearside (not yet fitted)
Sunroof panel
Sunroof seal
As well as any labour associated with the above items which I didn't do myself.
Also have a cache of spares which I've accumulated which aren't factored into the above. Spare headlights, tail lights, plastic trims, mirrors, door cards, front valance (brand new), foglight blanks, bumper trims, dash trims, hoses, stainless exhaust manifold, full OBC kit, map-light mirror, front splitter, bulb holders, headlight washer motors, HVAC parts, and the list goes on...
